Purchase SmartSDR+ subscription during $50 offer but prefer to hold off on SmartSDR V4 upgrade
Looking at the FlexRadio website, I can't find anyplace to purchase the SmartSDR+ subscription. Due to priorities and commitments, I prefer to hold off on the V3.x to V4.x update on my 6600. I would like to take advantage of the $50 off offer (ends November 30, 2025). How do I purchase the subscription while holding off on the on the V4.x update.
Ron, WB2WGH
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    edited November 20
    Info is here -
    How to Purchase SmartSDR+ or SmartSDR+ EA
    Scroll down a bit for instructions.
    Hi
    You have to upgrade (install) to v4.0.1 to then make the purchase. You can't do it without installing 4.0.1.
    You can always reinstall your previous version after if you like. You will have to reset the radio after the downgrade as the user databases aren't compatible.
  • Ronald Panetta
    Ronald Panetta Member ✭✭
    Mike, thanks. I guess I'm going to have to do the upgrade this weekend if I want to take advantage of the offer.
    Thanks, Ron WB2WGH
  • Doug
    Doug Member ✭✭
    I remain unclear as to how to purchase a SmartSDR+ license. I'm already running the latest version 4. I don't see any links or information on the download page. I would also like to take advantage of the $50 discount.
  • WX7Y
    WX7Y Member ✭✭✭✭
    on version 4 running SmartSDR on a computer click on Settings, then Radio Setup, at the BOTTOM of this box you will see two Green boxes, click on the option you want to purchase "Get SmartSDR+ or Get Early Access"
    I'm not sure how to do it on a Maestro but should be similar.
    hope this helps
  • Mark - W0QL
    Mark - W0QL Member ✭✭
    Where is the receipt? I purchased smartsdr+ using a credit card. Smartsdr+ installed and is working fine. The purchase does not show up in my “order history “. Anyone else have the same issue?
    Mark - W0QL
    Hi Mark, my order history shows my SmartSDR+ purchase. If you are concerned about it, you might want to send a note to sales at flexradio dot com.
