V4.1.3 bug report: microphone level meter not working remote
on7wp
on7wp Member ✭✭
"enable level meter during receive" does not work when enabled
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    edited December 4
    You need to log a support call with Flex so the issue can be tracked and looked in to.
    https://helpdesk.flexradio.com/hc/en-us
    What device are you using remotely?
    • MAC
    • iOS
    • SmartSDR for Windows
    • Maestro
    I run 100% remote and my Mic level meter is working. I can also confirm that it does work on a Maestro and Windows. That doesn't mean you aren't having the issue, but it is something unique to your setup it seems.
    If you restart the radio and the client, does the Mic start to work. I have to ask if you did confirm it was turned on in the radio settings.
    Make sure TX DAX is off as well. Lastly, please do a radio reset and see if it comes back. If not, then please follow up with our support team.
    Sorry, but we need more information please.
  • Gord-VA7GP
    Gord-VA7GP Member ✭✭✭
    edited December 4
    One more thought, @on7wp to re-iterate what Mike mentioned:
    Frequently, I find my DAX button is blue (selected) and I see no mic-audio on receive. I have no idea why DAX self-selects, but once I undo this, my mic-levels work during receive. So my quick suggestion for you: check to make sure DAX is not selected.
    HTH!
  • on7wp
    on7wp Member ✭✭
    Hello Mike,
    I was too fast and needed indeed to be more specific…
    SmartSDR W10 and W11 devices on several laptops, I see no compression meter working. I am using digital audio from my PC's microphone or an external USB microphone.
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Compression is displayed on the meter only when actually transmitting.
  • on7wp
    on7wp Member ✭✭
    wll it is not behaving like that when used loaclly so that is confusing. There the compression meterdoes work….
