CW Key quit working with V4
My bug quit working with V4, checked the settings and everything looks ok…Is there a new setting with V4?
No new CW settings. You might try exporting your profiles, then do a factory reset. If that doesn't help, post a screenshot of SmartSDR here so that we can see your settings.
What CW keying method are you trying to use ?? Paddles to radio? Straight key? External keyer? CW macros ?
Al, K0VM
As I mentioned in the original post, using a bug….always worked before, suddenly quit.
FYI, cable has been checked and is OK…
Did you try the factory reset?
Yes, did complete factory reset…
I am thinking there is a 8600 hardware failure….but no way to check the hardware
I have a help desk request, but no response yet…..been a few days…
Yep, that is the right thing to do. Hopefully they will get through the backlog soon.
I've seen the same. Note that you've got Iambic disabled (me too). If I enable Iambic, and hit the straight key, it'll make dits (so it's getting the input - just not acting on it when not Iambic). Then for some unknown reason, upon switching back to Iambic disabled it then seems to work. Sometimes I'd have to hit the key a few times to 'wake it up'… Give that a whirl and see how it plays.
@WA5YOM I use a bug too, and have the same settings that you do… and for me, it works as it always has. I get dits and dahs as always, from the Vibroplex bug.
I know it's not helpful to you 😞 but it's a data-point that does rule out the software…
Best wishes for a speedy and complete resolution
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
