Log4OM & SSDR4.0.1 Install?
Is anyone currently using Log4OM with SSDR?
I have an 8600, Win11 PC and can't get the two to connect. Need some advice on getting to work.
Tnx & 73 Paul w2eck
I'm using Log4OM along with N1MM with SSDR. In SSDR, in CAT Management tab in Log4OM settings, I set CAT Engine field to OmniRig. In Log4OM select Connect|CAT|Show CAT Interface. This should open the Omni-Rig Settings window.
Rig type: TS-440 (or "SmartSDR")
Port: same port number as defined in SSDR (see below)
Baud Rate: 9600
Data/Parity/Stop: 8/None/2
RTS/DTR: Low/Low
In Log4OM, Select Connect|CAT|Start CAT
In SmartSDR you will need a new CAT port: Protocol: CAT, Port Type: Serial Port. I named my port "Flex 6400". Click/select "Auto Switch TX slice".
I used to use HamLib, but found OmniRig to be more reliable for my use.
Glenn
Tnx for feedback - I did get it to work yesterday. For some reason one of the SmartCAT ports I had created was not working. So shifted to another previously created CAT port ad it's working.
Using TS2000 in OmniRig 38400
8 None 1 High High 100 400
Same setup as you in Log4OM
Someone in Log4OM community suggested I try HamLib - but majority seems to be using Omni-Rig
73 Paul w2eck
There is a file for Omnirig that is adapted to SmartSdr.
Unzip the file
Save smarSDR.ini in the subdirectory RIGS of the Omnirig directory,
then SmartSdr can be selected directly.
73 Klaus, DF3RP1 -
Klaus
Tnx - will give it a try. Been using the TS-2000 file - seems to work ok.
73 Paul w2eck
Hi Paul.. I'm using Log4OM with a 6700 using SliceMaster and it works pretty well using the TCP/Hamlib connection. It works pretty well. If you want info on 'how' just send me a note.
- 388 Community Topics
- 156 SmartSDR+
- 52 Aurora
- 970 Maestro
- 944 Genius Products
