Logging Multople Instances of WSJT-X
What do folks use to log multiple instances of WSJT-X?
Is seems problematic.
  • Al K0VM
    Al K0VM Member ✭✭✭
    Geoff,
    If you use the WSJT '—rig_name=****' option, then each unique rig_name has its own WSJT log directory
    including .ini file.
    Works for me.
    AL, K0VM
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hey Al…I initially set up WSJT-X using Slice Master. I use N3FJP logging software. If I have, say 2 instances, of WSJT-X open, one of FT8 and one on FT4, the logging software screen changes (displaying the mode of the last receive cycle presumably) at the end of each receive cycle.
    I actually have not tried logging a contact and my concern is that the contact mode will not be recorded correctly in ACLog.
    I'm not sure the timing of the transfer from the WSJT-X log to ACLog.
    I am not using the WSJT-X logs directly.
  • Al K0VM
    Al K0VM Member ✭✭✭
    I know nothing about Slicemaster or AClog..
    Sorry, AL
  • Geoff AB6BT
    edited November 2025
    Al… Do you use any logging program other than the WSJT-X logs?
  • Al K0VM
    Al K0VM Member ✭✭✭
    Yes,
    I use DX lab with JTalert in between WSJT and DXKeeper.
    AL, K0VM
  • Geoff AB6BT
    OK, if you are using WSJT-X with FT8 and FT4 instances do the contacts log correctly with the correct time and mode?
  • Al K0VM
    Al K0VM Member ✭✭✭
    Yes
    AL, K0VM
  • Geoff AB6BT
    I'm going to start a new thread with a similar but different problem.
