Remote with SoftEther VPN - Connecting Maestro Disconnects SmartSDR from 6700
Any suggestions for me?
SoftEther VPN installed to overcome CG-NAT
6700 at remote site accessed via AnyDesk to power on and off
Maestro at home site sees the 6700 and when I connect, it disconnects the 6700 from SmartSDR (both units up to date with version 4.0.1)
The Maestro only shows the top 1.5 inches of the screen, no audio, no frequency dsplay but it worked at the remote site when I did the software updates
I had help from Gerry, W1VE, on setting up the VPN, and he indicated the VPN tested OK.
Thanks for any suggestions! 73 from K1HC
Update 11/28:
Tried with a laptop loaded with SmartSDR 4.0.1 instead of the Maestro and still no luck getting it to run.
The laptop gives me an alert that SmartSDR is not responding.
Any sugestions for what to test next? Thanks from K1HC0
- 368 Community Topics
- 628 The Flea Market
- 8.1K Software
- 80 SmartSDR+
- 421 SmartSDR for Mac
- 270 SmartSDR for iOS
- 189 DAX
- 33 Aurora
- 243 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 914 Genius Products
- 331 Tuner Genius XL
- 450 Remote Operation (SmartLink)
- 778 Peripherals & Station Integration
- 993 Third-Party Software
