PGXL power meter on Maestro
Just installed PGXL 3-WAY and started to play around with it.
  1. Can't get the Amp Po meter to indicate anything
  2. Can't get the Amp SWR indication either
Same happened with SmartSDR
AMP indication is ok and the PGXL is working ok. Just cant get those indications on Maestro or SmartSDR for Windows.
Any ideas ?
73, VIlle oh1jd
    If you reboot the PGXL they should come back.
