Mac and Radiosport RS55SL SuperLite Travel Headset
Is anyone using this headset with a Mac?
I"m having some issues with USB stand alone microphone
Lyle
What connectors do I need for my laptop for Radiosport RS55SL SuperLite Travel Headset. Laptop only has one 1/8" port, but the headset uses two??0
Check your laptop manual. Your laptop may not have a Microphone input and if that's the case, you'll have to figure out some configuration for using a USB input for your mic. On the other hand, if your laptop uses a TRRS headset connection, where the connector has both headphones and mic connection, then you will need to buy or make a Y-adapter to connect your headset headphone and mic cables to one connector. Note that there are different TRRS configurations (tip, rings, & ground in different positions), so you need to know what your laptop requires. Your headset uses TRS, not TRRS connectors. The new Maestro version-C has the same problem, in that it requires a similar adapter, since it has only one input for both headset and mic. Search help for other posts to see if the Maestro solution applies to yours.
my RS55SL has a single TRRS 3.5mm connector.
73 Dave wo2x0 -
Hi Dave, So, then, the 2nd headset connector, that he apparently has, must be for PTT ?
Which would make the transition a lot easier.0 -
Billy, please describe your 2 connectors. Are they a TRRS and RCA or ???
Billy, is this the adapter you currently have with your headset?
- 395 Community Topics
- 674 The Flea Market
- 187 SmartSDR+
- 454 SmartSDR for Mac
- 276 SmartSDR for iOS
- 216 DAX
- 389 SmartSDR API
- 87 Aurora
- 325 FLEX-8000 Signature Series
- 984 Maestro
- 959 Genius Products
- 351 Tuner Genius XL
- 131 Antenna Genius
- 313 Shack Infrastructure
- 218 Networking
- 837 Peripherals & Station Integration
- 146 Amateur Radio Interests
