Slow boot time
When is this issue going to be resolved? It takes as long a 4 minutes for my 6400M to boot from OPERATE to RUN. V4 has failed us in so many ways. I have already changed the SD card thinking that was the issue, and as it turns out it is a glitch in the software. OK software gurus, where are you??
If you open a support ticket, they will get you looked at. This is not a problem with all radios. Just some (I know it looks like a lot, but with over 14,000 radios out there, it really isn't).
Hi radiopshopbob.
I had the exact same trouble with 6600M. It has happily sorted itself out (without me doing anything !!).
See my post "Slow Boot Time".
You could try raising a ticket as Mike advises, but I chose not to as I considered there were enough tickets being raised for more important things.
73 Mike.
Thank you all, but mine has had the SD card replaced and it worked fine for a day or two and then it went back to slow booting. You have to remember folks, I am not using SmartSDR to operate this radio, I bought the " M " model for a reason, I use the radio by it's self.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 269 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
