CW issues !!!!!!!!!!!!!
flex 8600 and V4.01 suddenly sidetone on cw gone, had to rebote radio. also noticed thar first caracter when sending fast cw first dit are missing. in S so its an i am sending.QSK has to be set to 0 delay else my first dit ar missing.so some BUG !!!!
    For CW QSK, to you have the ATU turned on? Does the problem go away if you set the delay to 125 or so?
    Have you opened a support ticket?
    edited November 2025
    Lars, I need some details please
    • SmartSDR Version - must be a current version, such as 4.0.1
    • Radio model
    • CW keying method - paddles if so via radio/Maestro
    • Is this a Keyer problem from N1MM?
    • Remote Keying via external software
    • SmartLink connection
    • ATU in used or standby
    • PGXL/TGXL engaged
    • CW Delay setting?
    • TX Delay Setting?
    I need enough details to try to recreate this. If others are reading this and are experiencing the same thing, I need the above details please. This will help isolate the root cause.
    Thanks, this all helps.
  • Lars Pettersson
    Lars Pettersson Member ✭✭
    radio type was in my post!!!! and sw!!
    No ticket made!!!!!
    No ATU or any of what you typed
    paddels in maestro
    this is a V4.01 issue never happend in prev versions.
    Lars, I need the rest of the settings please.
    Here is what happens when you don't open a ticket, and I apologize for how this sends. If the ticket doesn't exist, then we can't fix it.
    • PGXL/TGXL engaged
    • CW Delay setting?
    • TX Delay Setting?
    • SmartLink connection/ yes
    • ATU in used or standby/Bypass
    • PGXL/TGXL engaged/ Have none
    • CW Delay setting? /150, but set to =0 to get rid of missing dit
    • TX Delay Setting?/30
    • as i wrote this is a v4.01 issue
  • The sw 4.01 have a very uncertain functionality suddenly the cw issue are gone without any handson.
    Lets see what happens next!!!!
