Noise Blanker
I am running the latest version (v4.1) and I am trying to find out where to adjust the gain of the Noise Blanker. When I click on the NB button within the SmartSDR program, it must just turn the Noise Blanker on. I don't see anywhere to adjust the gain or sensitivity of the Noise Blanker. I need help on this one… Thanks, Bob
Hi Bob, the NR, NB and ANF/APF adjustments have been removed, at least for now. Mike, VA3MW mentioned that the engineer took them off because the new methods have been set to optimal levels.
Thanks, we have collected all the comments on the sliders to passed them on to the engineering team.
Another nobody asked for, just arbitrary change, kind like the profile autosave that took years to undo when it became user selectable which it should have been all along.
After upgrading to V4 my noise blanker is completely non functional. It worked quite well when enabling it when running V3. With V4 NB does absolutely nothing. APF when eneabled seems to have virtually no affect either. It was quite effective with V3.0
Upon further investigation. . . with V4 installed, I have used the API to enable/control the NB and APF levels. The noise blanker in V3, which worked quite well on my saw tooth AC power line noise problem (a blown lightning arrestor) is now totally ineffective with V4 noise blanker. I am listening to the noise in AM mode which clearly shows whether or not the noise blanker is working and how well.
Dave, W0FLS0
- 362 Community Topics
- 624 The Flea Market
- 8.1K Software
- 60 SmartSDR+
- 6.3K SmartSDR for Windows
- 180 SmartSDR for Maestro and M models
- 418 SmartSDR for Mac
- 267 SmartSDR for iOS
- 249 SmartSDR CAT
- 186 DAX
- 374 SmartSDR API
- 9.2K Radios and Accessories
- 28 Aurora
- 227 FLEX-8000 Signature Series
- 920 Maestro
- 905 Genius Products
- 327 Tuner Genius XL
- 116 Antenna Genius
- 283 Shack Infrastructure
- 199 Networking
- 765 Peripherals & Station Integration
- 986 Third-Party Software
