Smartsdr 4.0.1 basic sliders missing
Wish my AU-520M was here. I would like to fire up Visual Studio and see what effect adjusting the different values would do.
I used NR on SSB and this works though not as good as v3. I used the NR slider to optimize SSB reception (v3). With the slider I could do significant NR on v3.
It doesn't seem to work on CW, or maybe just small amount. I also notice the NR such as it is in v4 on CW seems to be 'learning.' But not much. It does not seem useful,
Also, on CW the rf gain slider seems to have less effect with NR on. On this I need some more tests since the effect is less observable on CW (v4.01).
Follow up. The RF Gain is working on CW but the NR at any bandwidth is less than v3 with the slider for NR. RF GAIN setting seems important to NR function
Its a hmmm. Like several others I'd like the sliders back. Everything I've noted is qualitative and interpretation may be off.
Just updated my 6500 from v2.9.1 to 4.0.1 without problems. Nothing to report except I cannot understand why the DSP sliders have gone. I used them a lot in my noisy environment. I do not get a sense that much happens when the separate items are selected… are they active but fixed or just not activated yet? 73 de Jim G3YLA
Like several others I'd like the sliders back.1
As a keen CW operator I use the APF feature frequently. The loss of the slider is an issue for me so have reverted to v3. Hopefully in the future the APF slider will be reinstated.
I use N4PY Rig Control with my Flex. N4PY has sliders for APF, NR, ANF, NB, and WNB.
73 de K1ESE
John
Several applications have levels control for the DSP functions in lieu of the omissions in v4.
By far the best, in my opinion (and I have tried them all), is SliderMaster by VE3CKO. Mike has done a good job and will be refining it further to be more compliant with available screen space. Check it out at
There is also FRStack V4 though accessing level controls in it is a bit cumbersome. Station Master too has level controls.
@Erik Carling EI4KF That's what I am running. Works great.
FRStack works great once you get used to using it.
@Erik Carling EI4KF That link requires a password
For which, email Mike:
ve3cko@interpc .ca
- 384 Community Topics
- 650 The Flea Market
- 150 SmartSDR+
- 263 SmartSDR CAT
- 288 FLEX-8000 Signature Series
- 962 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
- 801 Peripherals & Station Integration
- 142 Amateur Radio Interests
