Using DIV / ESC on Maestro C ... TX Issue?
Anyone running into this ?????
I'm running the latest 4.0.1 code … and the Maestro in running on battery power.
Maestro works flawlessly until I turn ON DIV / ESC and attempt a transmission. Believe it or not the Maestro sounds like it farts and then I lose all audio. The functionality of the Maestro appears to stop and after less than minute it disconnects and reconnects to my 6700 and things appear to be back to normal.
I'm gonna try a few other tests using my 2nd Maestro C and also only using my 6700 and see what I come up with. It may just be this Maestro and not my other one … who knows …
I will send an update later …
I also have SmartSDR+ … do I have to wait 30 days???? …. Hi Hi ….
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsPlease open a support ticket for this so it get tracked accurately.
thanks
I ran into the same issue with my 2nd Maestro C …..
This time I reloaded the GLOBAL profile I was using and things went back to normal ….
I'm going to try a TX on my 6700 only and see if I have the issue w/o using a Maestro ….
Same issue when ONLY using the 6700 ….
SmartSDR locks up and I receive the attached bubble in the lower right side of SmartSDR ….
Will do Mike ….
UPDATE: The issue was NOT my Maestro ….
I did a factory reset to both radios 6700 & 6600M and rebuilt my GLOBAL, TX & MIC profiles and all appears to be okay now.
- 197 SmartSDR+
- 322 Shack Infrastructure
- 227 Networking
