Digital voice Keyer
WX7Y
WX7Y Member ✭✭✭✭
I was just trying to copy my pre-exiting WAV files and I get a RED error when it tried to upload the Files, Is there a format that the WAV files need to follow or a different file type?
Thanks for any information
Bret WX7Y
  • iz7auh
    iz7auh Member ✭✭✭
    Dear Bret, making file WAV with Audacity (freeware) and convert it in stereo and frequency 24000 Hz.
    Work fine.
    best 73 de IZ7AUH
    This is from some previous testing I did with the developer a while back.
    Give it a try.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Thanks guys, I have tried one files but got the same error using your settings Mike, Continuing to test different options.
  • WX7Y
    WX7Y Member ✭✭✭✭
    All my existing WAV files won't work with your settings Mike so it must be magic.
    I Re-recorded the ones I could using SmartSDR DVK and they work fine, Looking at these files they are exactly the same format as my original files, I also checked the File permissions which are the same, The file location is on my desktop in my Flex Profiles folder so I don't think it's a permissions issue.
    maybe they get this fixed in a feature release
    If the 24000 doesn't work, open a support ticket please so it gets tracked.
  • WX7Y
    WX7Y Member ✭✭✭✭
    Sent support ticket #76154
