DVK - download and edit WAV file
eyrich
eyrich Member
I have downloaded a DVK file but can't find a program that will open the file. All of them say unsupported format. Have tested Audacity, the built-in Windows 11, and VLC
Has anyone found a way to edit the file?
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    edited November 6
    Hi eyrich… what are you using the DVK file for? According to Copilot, it seems to be proprietary file format, mainly used in gaming…
    Did you mean you were trying to edit a WAV file?
  • eyrich
    eyrich Member
    Digital Voice Keyer - it downloads as a WAV file - but no program I have tried can open it.
  • Mike VE3CKO
    Mike VE3CKO Member ✭✭✭
    edited November 6
    Another example of online AI tools guessing. Not sure what the search term you used. Think about it. DVK in FlexRadio terms is Digital Voice Keyer. I don't think FlexRadio named it Digital Voice Keyer so to align with a binary data format standard. Why can't AI just say, "I don't know", like my grandson started saying when he was one year old. Instead it spits out garbage disguised as an intelligent response but is just nothingness.
    The Release Note say the format is: 2-track, 32-bit float, 48 kHz WAV file
    Google AI search results for "what software can be used with a 32-bit float, 48 kHz WAV file":
    "Most modern Digital Audio Workstations (DAWs) and video editing software can handle 32-bit float, 48 kHz WAV files, including popular options like Audacity, Pro Tools, Cubase, Studio One, and Reaper. Video editing software with audio capabilities, such as DaVinci Resolve and Adobe Premiere Pro, also support this format"
    In my Audacity, I can export audio in the 2-track, 32-bit float, 48 kHz WAV format. Unfortunately I'll have to wait til the end of the month to get my DVK enabled so to start playing with the DVK feature. If you want to send me that wav file you downloaded from your radio, I can check it out with my Audacity to see if can open it up an edit it. email is ve3cko at interpc dot ca.
  • eyrich
    eyrich Member
    Please stop with the AI slop,
    As stated in original post already tried: Audacity, the built-in Windows 11, and VLC.
    I am asking for anyone that has successfully edited the downloaded file from DVK.
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    I use Audacity, free and very easy to use.
    You can record using it or edit, I always trim the start and end of the WAV file using it.
    Rich
  • iz7auh
    iz7auh Member ✭✭
    Dear I uplaod all my WAV file but it's important to change frequency to 24000HZ stereo channel and work fine!
    Using Audacity it's free
