Creating Transmit Profiles In the Flex 6400 Question
KG5PTE
I have a question. Can you save a transmit profile on a 20 meter frequency on ANT 1 on the TGXL and then save a second transmit profile on 20 meters (Same freq) on ANT 2 ? So that latter you can pull it up and decide which antenna you wish to transmits on using the TGXL ?
Finally is there a way to rename ANT 1 or ANT 2 to the antenna it is connected too such as hex beam and the Dipole?
Thank you.
The memories (profiles) in FRstack handle this easily.
You know I never thought about FR Stack thank you. can you tell me where this is set at in FR Stack ?
Thank you.
- 391 Community Topics
- 664 The Flea Market
- 441 SmartSDR for Mac
- 206 DAX
- 62 Aurora
- 976 Maestro
- 950 Genius Products
- 348 Tuner Genius XL
- 128 Antenna Genius
- 308 Shack Infrastructure
- 216 Networking
- 819 Peripherals & Station Integration
- 145 Amateur Radio Interests
