Creating Transmit Profiles In the Flex 6400 Question
I have a question. Can you save a transmit profile on a 20 meter frequency on ANT 1 on the TGXL and then save a second transmit profile on 20 meters (Same freq) on ANT 2 ? So that latter you can pull it up and decide which antenna you wish to transmits on using the TGXL ?
Finally is there a way to rename ANT 1 or ANT 2 to the antenna it is connected too such as hex beam and the Dipole?
Thank you.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    The memories (profiles) in FRstack handle this easily.
  • KG5PTE
    KG5PTE Member ✭✭
    edited November 2025
    You know I never thought about FR Stack thank you. can you tell me where this is set at in FR Stack ?
    Thank you.
