Creating Transmit Profiles In the Flex 6400 Question
KG5PTE
I have a question. Can you save a transmit profile on a 20 meter frequency on ANT 1 on the TGXL and then save a second transmit profile on 20 meters (Same freq) on ANT 2 ? So that latter you can pull it up and decide which antenna you wish to transmits on using the TGXL ?
Finally is there a way to rename ANT 1 or ANT 2 to the antenna it is connected too such as hex beam and the Dipole?
Thank you.
The memories (profiles) in FRstack handle this easily.
You know I never thought about FR Stack thank you. can you tell me where this is set at in FR Stack ?
Thank you.
- 383 Community Topics
- 639 The Flea Market
- 146 SmartSDR+
- 435 SmartSDR for Mac
- 273 SmartSDR for iOS
- 262 SmartSDR CAT
- 201 DAX
- 958 Maestro
- 934 Genius Products
- 342 Tuner Genius XL
- 304 Shack Infrastructure
- 142 Amateur Radio Interests
