Best remote devices for Flex control
My KMTronics must have died as PSTRotor AZ program can no longer connect to it even using the fixed IP address over the LAN. This was the KMTronics WEB controlled 8 relay board.
Is there a simpler method just to provide a remote relay open/closing to control the Flex remote in on/off and also provide a remote PTT . a 4 relay board would suffice for what I need overall but 8 relay is ok. Is the Denkovi board a better choice? What is the latest and greatest method for remote control relays?
Thanks Lar K1UO
Any IOT device you can find on Amazon.
Is it possible your KMTronic took a lightning hit?
@ Mike va3mw: Thanks Mike, I dont think it took a lightning hit but one never knows when not Home :))
Will try a replacement unit. I swapped LAN cables and ports on the 16 pos LAN switch so new KMT is next I guess.
I have been using them for years. The only problem I had was with an old one that forgot its IP address and it defaults to the ship IP address. If you can, see if you can connect to it that way. KMTronic was pretty helpful when I told them about it.
- 650 The Flea Market
- 151 SmartSDR+
- 263 SmartSDR CAT
- 48 Aurora
- 964 Maestro
- 936 Genius Products
- 343 Tuner Genius XL
