AG stopped working
Got up this morning and the AG is not found on the network. It is powered up and shows network light flashing but the utility does not find it and when I ping the IP it is not found.
Greg
AB7R
Greg
There is a reset procedure for Bricked AG
Ian
KM4CQG
12. TROUBLESHOOTING12.1. Re-riving a bricked deviceThe most typical scenario of bricking an AG is interrupting a firmware upgrade or failing afirmware upgrade due to a bad network connection.AG features a bootloader software enabling you to reinstall the firmware at any time.The bootloader uses a fixed IP address – 192.168.1.250 so make sure your network is using thesame subnet.Follow these steps to take to reinstall firmware on a bricked device:12. remove DC power from AG13. move DIP 8 to ON position14. turn DC power back on15. Open the app,16. Click on the Settings wheel and select Firmware Recovery17. You will be prompted with a window that looks like this:18. click Yes19. wait for the progress bar to fill up20. move DIP 8 to to OFF position21. remove DC power from AG22. turn DC power back on
After doing this procedure are all of your settings lost?
Bill AB7AA
@ AB7AA Yes Bill . toggling Bit 8 off normal and then cycling the AG power off/on will cause the AG to factory reset and your settings will; be lost.
Lar K1UO
Thanks Larry. I surmised that it probably would. Fortunately I found my problem and regained communication with the AG and didn't have to forgo the pain. I have several backups now of the configuration.
Bill AB7AA
Greg, to benefit others, what did you find?
73 Dave wo2x
I did a reset with the dip switch and rebooted. Came back no problem.
Greg0
- 656 The Flea Market
- 438 SmartSDR for Mac
- 385 SmartSDR API
- 52 Aurora
- 294 FLEX-8000 Signature Series
- 969 Maestro
- 941 Genius Products
- 345 Tuner Genius XL
