Smart SDR 4.0.1, DM780 6.8.0, CW Split function fail
            I've been using DM780/Winkeyer with previous versions of SmartSDR for years. Just upgraded to SmartSDR 4.0.1 on a Flex 6500 a couple days ago. This morning I tried to work a CW station running split. When I clicked SPLIT, it worked normally. Slice A had SPLIT illuminated and Slice B opened a couple KCs up, in TX.
As soon as I transmitted a macro in DM780, Slice B stayed, but TX went back to Slice A. Slice A then showed SPLIT and TX illuminated.
I'm usually pretty good at figuring this stuff out, but this one has me stumped as I don't know if this is a DM780 issue or 4.0.1. I checked Options in DM780 and everything seems as it should be.
Suggestions welcome,
Mike KF9AF
            on my 6500 the same symptoms, split doesn't work properly1
Mike,
I would open a ticket. And, is this the new version of HRD or old version?
You can look at the CAT log and see if HRD sent new commands to change any of the focus.
Mike-VA3MW,
When the latest version of HRD v6.9.0.17086 (27-Oct.2025) came out, I installed it and my Logbook entries were GONE😲, so I reverted back to the previous version and my Logbook was restored. (Apparently I'm not the only person that had that issue. )
I had several different test variations typed out, and in the midst of that after opening and closing the Rig Control and DM780 screens a couple times, all of a sudden the issue is gone. This was after I duplicated the TX switching slices several times during testing. I changed nothing.
Weird. Guess I'll just keep an eye on it and if it acts up again I'll open a ticket if you think that's the best route. Thanks for replying!
Mike KF9AF
 - 361 Community Topics
 - 620 The Flea Market
 - 8K Software
 - 32 SmartSDR+
 - 6.3K SmartSDR for Windows
 - 415 SmartSDR for Mac
 - 267 SmartSDR for iOS
 - 252 SmartSDR CAT
 - 188 DAX
 - 378 SmartSDR API
 - 9.2K Radios and Accessories
 - 27 Aurora
 - 928 Maestro
 - 902 Genius Products
 - 325 Tuner Genius XL
 - 118 Antenna Genius
 - 288 Shack Infrastructure
 - 202 Networking
 - 141 Contesting
 - 982 Third-Party Software
