My thoughts on new Subscription by Flex for SmartSDR V4
WX7Y
WX7Y Member ✭✭✭✭
Well my thoughts are Everyone will get a free upgrade to version 4 even if your radio is on Version 1, BUT the features won't be enabled.
I think if you STOP and think about it, Flex with version 4, they NOW only has to support ONE version of firmware/software and they can pull there resources to concentrate on just one software platform not having to port over to Versions 3, 2 or 1. SMART THINKING!
I think personally FLEX is smart to do things this way as I have owned my 6700 for almost 14 years and bought and sold many FLEX radios in the past as well as a new 8600 and to spend $200.00 for a feature I find useful per radio is not a great deal.
Personally I own 3 Flex radios a 6300, 6700, and the 8600, for me the 6300 is in my RV and is on version 3 and I will never upgrade past the Basic v4 UNLESS they come up with a DESENT replacement for the Antiquated SmartLink with a real VPN but that is probably unlikely, for the 6700 I probably won't upgrade that one either past V4, if you ask me the BEST Radio FLEX has ever made but has some years on it and it is my backup Radio, But I will probably upgrade the 8600 when a new worth wile upgrade comes out.
Now if you have several radios on different version's of SmartSDR you have to always be using different version of SmartSDR for what ever Radio your using if you haven't paid for a update for that radio, With the new Version I hope just one version of SmartSDR will be required but all the features won't be enabled on a different Radio's. AGAIN SMART THINKING!
So if there are no new features that you don't want or need then DON'T pay for the subscription services for that year, This is not much different then we have had in the past but now there won't be a new version of software NUMBER but your buying features instead you will STILL get the Updates to fix bugs and issues with the features you already own or purchased.
  • Trucker
    Trucker Member ✭✭✭✭
    edited September 26
    Version 4 is free to all users including v1 and v2. But, features that happened from one of those versions to the next will not be enabled if you are on the older version and upgrade to version 4. Only the features you had in your previous version will be enabled even if you are on version 4. ( Basic) If I understand the announcement correctly, if you then pay for a subscription, you will then be able to add the upgrades from v2,and v3 to your radio along with any new features that come out while your subscription is active. And you will continue to be able to use all of those features after your subscription expires. A much better solution than some subscription services and software that people use.
  • Mark_WS7M
    Mark_WS7M Member ✭✭✭
    edited September 26
    As I said in another thread, I am fine with supporting flex with a $200 yearly payment. But I use only CW and digital so if the features that will be withheld without the payment are targeted for things like APD, or voice related improvements then it will not be useful to me.
    Also, I've switched to SmartSDR Mac which frankly works much better than the Windows version. If the V4 subscription stuff doesn't work with SmartSDR Mac then I won't buy it likely.
    I do own two flex radios. I think the model would work much better on a user basis rather than radio basis. There is a guy in the other thread that has 6 Flex radios. That's a lot of money for all the radios.
  • Dan Trainor
    Dan Trainor Member ✭✭✭
    Yes, Every radio gets to own version 4 "base" version for free. Remember this is NOT a subscription model.  It is an ownership model with an option to purchase extended features.  So, you are absolutely correct, a new (or old) radio that has say version 3 will now need to pay $199. to get a full featured version 4. A version that includes these extended features. As the customer, you are in effect buying extended features. In a true subscription model, you are perpetually paying an ongoing monthly / annual fee for access to the software at some defined level.  But, that is not the case here because, despite the name, this is NOT a subscription model.  Not even close to a subscription model.  Anyway, the smart play is to start with the version 4 base version then wait as long as you can until, at some point in the future, some extension gets released that you find really compelling and you want it.  Then you pay for it.  It is a purchase of the feature.  It will cost $199 to enable access to it.  In other words you own it.  Now you no longer have the base version, you have an extended version of the software as a result of a one-time purchase of the same.  Now, say 3 years later another compelling feature gets released that you must have, it will cost you $199 to own it.  So, in reality, this is a "pay for feature(s)" model and NOT a subscription model.  If you never find a released feature worth having, you never pay a dime.  Your cost is $0.  Your cost is zero because you did not purchase an extended feature that you never wanted, because it was not useful to you.  So, therefore you can choose to not participate in this licensing scheme.  Again, the cost is $0, as this is NOT a subscription model where an ongoing monthly / annual is required to have access to certain levels of functionality. In a subscription model, if you stop paying your bill, your access is closed off to you.  This is not the case with the new Flex licensing scheme, as it is a "pay for feature(s)" model of licensing.  de WA1QZX
    I see what you are saying there, but I want to make it very clear that you do not have to buy V4 to get to the base V4. I had it read it a few times to make sure what you saying is correct. But, that is just my brain.
    V1 upgrade to V4 is free, but they do not get MultiFlex or SmartLink but they get SmartControl
    V2 upgrade to V4 is free, but the do not get MultiFlex but they get SmartControl
    V3 upgrade to V4 is free with all the same features as V3.
    V1 and V2 users can buy those features — I am not sure exactly on that process just yet.
    Every FLEX-6000 and FLEX-8000 owner gets a FREE upgrade to V4.0 with the same features they they originally had.
    V4.0 will now be the new base that all the new code is developed on. All future fixes will only be on V4. There is planned to be 1 more released soon of V3 (always subject to change). That is the status as of this timestamp.
  • Dan Trainor
    Yes, thanks for upgrade caveats for V1, V2 and V3 radios. I think it is Smart for Flex to motivate a convergence to a single V4 code base by providing all future fixes to only V4. Less labor costs to maintain. And it is free for all customers to advance to base V4 with caveats noted - A good thing. Extended features become a optional voluntary choice of customer at a purchase cost of $199. Otherwise, total cost of ownership of V4 base with ongoing bug fixes is $0. Dan WA1QZX
  • K3SF
    K3SF Member ✭✭✭
    one question…
    What version of Windows MUST the SSDR client be run. Windows 10 or Windows 11 and what build..
    and since the SSDR client is essential element of the radio system what are the anticipated restrictions going forward with Version 4.
    Paul K3SF
  • Trucker
    Trucker Member ✭✭✭✭
    I have had no problems using Windows 7, 10, or 11 with SmartSDR.
    @k3sf - It will run and continue to run on multiple versions of Windows.
    However, if you have an issue, we will only 'support' SSDR running on a currently supported version of Windows. That will be Windows 11 shortly.
  • w1mbb
    w1mbb Member, Unconfirmed
    edited September 29
    What version 4 enhancements have been released that apply to 6000 series radios?
    Version 4 has not been released yet.
  • wb0z
    wb0z Member ✭✭
    Most companies do this service type now but two major issues I did not see addressed:
    1. Most vendors will give new hardware purchasers a 1 year license. Especially for a company that sometimes is on backorder, you have no ideal as to what features you will "OWN" when your radio ships.
    2. Now this is the big one - APD was promised to be soon after radio shipped. Now we just have a beta release of that feature without the ability to use external amps. Because the was listed as available to all 8000 series soon after shipments, it should be one feature that is still included in the v3 bug releases. Otherwise all those announcements were false advertising. In fact, several Flexradio videos talked about the new processor and FPGA would allow new more advance features due to the increased performance. We all bought into that. But now it sounds like that statement should have been "The new processing power will allow us to make additional pay for use features"
    I really feel Flexradio needs to address APD in V3 (full release including amp usage) and give us a 1 year free feature upgrade. After that, I fully agree with recovering the cost and users of 1+ year old device paying for new features.
  • John KB4DU
    John KB4DU Member ✭✭✭✭
    Not to mention the numerous “known issues” unfixed for years.
  • iz7auh
    iz7auh Member ✭✭✭
    I'm also very perplexed by this FRS policy. I expect them to add multiple implementations in a year, otherwise what's the point of paying $300? I also expect the features they add to be operational and not to use us as their beta testers. In fact, DVK doesn't work properly on Maestro. Is it possible that their engineers haven't verified it? I see so many filters, some work well, others don't. There's no way to adjust them. I think their choice was a bit reckless. They would have done better to include a marketplace for individual features, and each of us chooses what to add and what not to add.
    I conclude by thinking that it would be appropriate for FRS to include a roadmap of the implementations they will make during the subscription period because I need to know what I will encounter during my subscription year. What if by chance I subscribed today and they add new features the day after my year expires? What did I pay for this subscription?
  • KC9KZM
    KC9KZM Member ✭✭
    I agree totally. I paid for the possibility of getting new features that I would find useful-I might not find any of them useful. Money wasted. Wait for features to become available then spring for a subscription if you want them ?? A software/ feature road map for at least a year out would be nice.
    I would much rather pay for the features à la carte.
    The reality is that none of the user comments / suggestions will change a thing.
    And so it goes……
  • Erik Carling EI4KF
    I posted my complaints about this subscription nonsense on the day it was announced. I knew it would be like this. Yes, as KC9KZM intimates there will be those who think its wonderful and fair enough I respect their feelings. But it was clear that the policy is divisive, ill thought out and in the long term will not do any good to Flex users or the Company itself.
    In mitigation, providing you do so before end of November, V4 can be acquired for less expense than the old system of $200 for any new major version release i.e. V3 to V4. So you might as well get V4 now.
    But don't be surprised, having made your payment, that there are issues. I have a long list but just as a few case in points: IZ7AUH question above about lack of a roadmap. Then there is this 30 day wait and what if a subscription expires after downloading a version with a new feature but before the 30 day period has ended: is the feature is still available or not? It seems not but again there is no explanation.
    Why is it so ambiguous as to what you actually get? Not only what features and when but also with what is being removed that is not being announced, e.g. DSP user level adjustment which exists but is denied to Windows SSDR users.
    Flex presumably wanted an extra income stream. There are many ways to achieve that without impacting users, wrecking company reputation and negatively impacting on potential customers' product choice thought processes where now they are likely to dismiss Flex as an option. And there are many ways to bring new features to the software in professional, smooth and exciting ways without going through payment tiers, subscriptions, expiries, unclear documentation and chaos.
  • KC9KZM
    KC9KZM Member ✭✭
    I just finding this paying in advance for unknown features/capabilities a bit odd. Imagine using this model in the automotive market ?
    Buyer pointing to window sticker-"sir what is this item listed as "Advanced features- Optional purchase- $3000"? There is no description as to what they are !"
    Salesman- "Why yes, that's the beauty of our model !"
    Buyer- "but I don't know what I'm getting for my money ….."
    Salesman- "You seem like a sharp fella, but you do realize you'll know exactly what you paid for when you get the features ?-So what's the problem ??? Our customers love this ! Now let's sign you up….."
    OBTY, I did purchase the SDR+ option…..
  • hochocke
    hochocke Member ✭✭
    I recently purchased SmarttSDR+ for my 8600. When will the new features be available to me?
    Howard N8HO
