CWX active when its not?
Hello all,
I setup some text in CWX so I can send these strings of characters at the press of a function key. That all works well, but I noticed that even when CWX is not selected the press of the associated function key still sends the text. Is that normal? Seems like if CWX isn't selected it shouldn't send the characters.
    Hi Phil, yes, that is how it works. Further, CWX does not honor the Breakin status. In other words, it will transmit whether Breakin is on or off.
  • PhilM
    PhilM Member ✭✭
    OK if that's normal behavior. Doesn't seem like a good idea the way it is but i guess anything else would be an enhancement request. I wonder if the MACOS version behaves the same way.
    Phil, NC3S
