Change STATION box at the bottom of the screen
After I installed the latest version I noticed that the STATION box says I am "w6jjj". I can enter my call (k5XH) but clicking on the STATION doesn't do anything. The next time I start SmartSDR I am back to being w6jjj. From what I read elsewhere on the Community this should work but it does not. Did something change with 3.10.10? Never had this problem before.
Thanks, Mark K5XH
  • Erik Carling EI4KF
    Where are you entering your call, Mark, that gave you no problem before but does now? This leads me to believe that I am mistaken so forgive me if this is bad info:
    This is where I set my computer name which is what is displayed in SmartSDR.
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    Hi Mark… if you mean the station id @ the bottom of the panadapter, here
    Then it's just a type-over field. HOWEVER, as I found out, you need to press ENTER after you put in the new call sign. Then it should hold for the next startup.
  • K5XH
    K5XH Member ✭✭
    Eirk - Not trying to put my computer name in that spot - just my callsign.
    Don - I think I tried that but I will do it again tonight.
    Seems like what worked before was to click on the word STATION after entering a new call. STATION was actually a button with an event trigger.
    Thanks for the comments!
    73 Mark K5XH
    If I name my computer EI4KF, that is what appears! But Don is correct, write it in and press enter and hey presto. I think flex have changed the behavior of STATION and I see on a DX Forum two weeks ago some similar confusion..it isn't just you (or you and me in fact).
  • K5XH
    K5XH Member ✭✭
    Hitting ENTER after changing the text worked. Thought I had tried that but apparently not! Thanks to all who commented.
