PGXL Standby mode PTT operation
Mike_VA3SP
Member ✭
With PGXL in Standby mode, I noticed that relay(s) change state when the PTT line state changes. I thought RF should just pass through bypassing the amp. What is/are the relay(s) controlling? Should I disconnect the PTT line when I want to operate barefoot?
Hi Mike
I'll need you to elaborate.
- Relays in the PGXL?
- How are you keying the PGXL? Via a LAN/FlexRadio connection or via an OEM radio and the PTT/RCA connector.
- What version of firmware is on the PGXL
thanks
Yes, I'm referring to the relays in the PGXL.
Using an OEM radio (FTDX101) keying using PTT input on back of PGXL.
Firmware v3.8.9.
With amp in Standby-mode, keying PTT causes relay(s) to toggle in the PGXL.
SWR at xciter doesn't change whether PTT is connected or disconnected. I haven't investigated further yet as to any differences which might be happening.
Also, this is using port A. I haven't tried with port B.
My assumption is that in bypass - standby mode there should be a simple path between RF in and out so nothing should be changing.
Just want to understand what's up. Would be helpful if there was a schematic :smile:0 -
I can think of a few possible reasons this might be happening.
My guess is that it’s external to the RF chain, perhaps in the power supply area, and if that’s the case, the effect would be minimal beyond the audible clicking.
You may want to reach out to 4O3A directly for confirmation. To my knowledge, you’re the first person to bring this up, which could be because most operators are using LAN keying with FlexRadios instead of PTT.
Thanks, Mike. With a bit more investigation, I believe that the relay(s) is associated with the PTT Output as this o/p shorts when the PTT Input is closed and the relay actuates. But I've submitted a query to 4O3A to confirm.0
- 361 Community Topics
- 620 The Flea Market
- 8K Software
- 34 SmartSDR+
- 6.3K SmartSDR for Windows
- 416 SmartSDR for Mac
- 267 SmartSDR for iOS
- 252 SmartSDR CAT
- 188 DAX
- 378 SmartSDR API
- 9.2K Radios and Accessories
- 27 Aurora
- 224 FLEX-8000 Signature Series
- 929 Maestro
- 903 Genius Products
- 326 Tuner Genius XL
- 118 Antenna Genius
- 288 Shack Infrastructure
- 202 Networking
- 141 Contesting
- 983 Third-Party Software
