Slice-Master v.0.11.0g program don't work with new firmware 3.10.10
Mike, I mentioned the problem with Winkeyer some time ago, and it has been solved wonderfully in version 3.10.10. Everything is OK at the moment, so I don't want to use 3.9.19 again.
tnx 73 de Peter
Has anyone found a way to resolve the issues between slicemaster v0.11.0g and SmartSDR 3.10.10.
Not only has this issue been reported by me and a few other folks, I get people reaching to me on how I work around it. I've had several tickets open with the help desk.
What I do is first is choose a different DAX IQ channel (from 1 to 2, from 2 back to 1) and that seems to make both applications in the relationship happy.
However, when the radio becomes sluggish, with RTT reading high (as measured in Maestro/Network or in SmartSDR/Diagnostics in the 1000-9000 ms range), and won't respond to Cat controls commands, restarting slicemaster returns latency on the radio to normal (in my case between 20-75ms).
Chris de WX7V
Hi, I don't think anyone has solved the problem I described in my first message in this session... and I haven't received any information from any OM. Has anyone solved it? I don't think it's a problem with modifying the Slice IQs but rather a problem with the dialogue between the Slicemaster application and the latest release 3.10.10. So has anyone solved it? Thanks.
Is there any word from Don on a solution to this? I have exactly the same issue. I was able to get it to operate 1 time and it appears to be related to Slice Master seeing the DAX channel correctly. I could not repeat the process to get it to run again.
I gave up trying to get 3.10.10. t work with S;licemaster and Flex says it isn't their problem and are not working on a solution so OI have gone back o 3.9.19 and it works fine every time
I've gone back to SmartSDR v3.8.23 and everything works as expected (minus the bug fixes in 3.9.x)- like the SMART-9370 RX antenna indicator is blank when using diversity).
- 352 Community Topics
- 615 The Flea Market
- 8K Software
- 3 SmartSDR+
- 6.3K SmartSDR for Windows
- 412 SmartSDR for Mac
- 267 SmartSDR for iOS
- 250 SmartSDR CAT
- 187 DAX
- 375 SmartSDR API
- 9.2K Radios and Accessories
- 22 Aurora
- 212 FLEX-8000 Signature Series
- 922 Maestro
- 894 Genius Products
- 323 Tuner Genius XL
- 116 Antenna Genius
- 284 Shack Infrastructure
- 200 Networking
- 138 Contesting
- 974 Third-Party Software
