Why do I have to sigh in to my FLEX8400M
Keith
  • John WA7UAR
    John WA7UAR Member ✭✭✭
    As I understand it, you are signing into the built-in Maestro client head bolted onto the radio.
    You can sign into that client, or sign into SmartSDR for PC or Mac software clients to also access your radio hardware. Signing in allows for connections involving SmartSDR DAX and CAT to choose the proper client that is connected to the radio.
  • Ken Wells
    Ken Wells Community Manager admin
    "Signing In" on a Maestro, M-Model Front Panel, or SmartSDR for Windows is only required if you plan to access the radio remotely from outside your Local Area Network using the SmartLink feature.
    If you only plan to operate Locally, or as a "stand-alone" radio, it is not necessary to "sign in" at all.
    To add to what Ken mentioned.
    No, you never need to sign in. That is only for SmartLink/Remote operation.
