Multiflex not working with new 8400 with V 3.10.10
howardsh3t
I had been running a 6400 with many levels of firmware including 3.10.10 with no problem at all running Multiflex.
With my new 8400 each of the interface devices work correctly and when I look at the config, multiflex shows up. When I try to connect the 2nd client, I get the message that the radio is not available and multiflex not active. If I use the Maestro as the 2nd client, I can connect it as smart control and that works fine.
How do I make sure, that Multiflex is active on the radio and each of the clients sees this?
Please open a support ticket. thanks
I have the same issue. Will open a support ticket.
- 371 Community Topics
- 94 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 937 Maestro
- 54 FlexControl
- 996 Third-Party Software
