Noise reduction persistence with mode changes
If I set the noise reduction level to let's say 50 in CW mode and I then change modes to LSB or USB and then back to CW, the noise reduction is disabled and set to 0.
Am I missing some basic configuration here or is this the way it is? I have both global and TX profiles defined but it seems that noise reduction levels are not saved with these profiles.
In the meantime, I'm working on a node red flow to set the noise reduction level whenever I change modes.
Hi Les.. as far as I know (and see) NR is set 'per mode' so yes, if you switch from CW to SSB directly, you'll lose your AGCT and NR settings.
What I (and some others do) is use Global Profiles to store best settings for each band and operating mode — e.g. a profile for 20m CW, another for 20m phone, another for 15m CW, etc. Then, just select the profile to switch bands and modes. Another advantage is that you can set the panadapters to only show that portion of the band as well, and set other parameters such as bandwidth, filters, etc. mode-by-mode.
Please follow up with a support ticket. thanks
Don, thanks for your reply. Indeed, noise level settings are stored with global and/or transmit profiles. I misspoke about that. However, let me explain my setup. I was too brief in my posting.
I do SO2R. I have a profile for SO2R 20-15 and another for SO2R 20-10. The profile stores everything including operating frequency. Let's say that both profiles have stored 14.03 as the operating frequency for 20m. I start with profile SO2R 20-15 and I tune the band to find a quiet frequency, let's say 14.025. I start running on 14.025. I'm doing S&P on 15m for a while. Now I want to switch the second radio to 10m to continue S&P on 10m. If I do this by selecting profile SO2R 20-10, I lose my operating frequency on 20m. It gets reset back to 14.03. No good!
So, I don't switch profiles when operating. I use node red on my PC to send a command to the second radio to change the slice receiver (e.g., slice tune 1 28.03). This quickly switches radio 2 to 10m without changing anything on 20m, so my running isn't interrupted in any way. So far, so good. The noise level settings are maintained.
The problem occurs when I switch modes by sending the radio a command like "slice set 0 mode=USB". This resets noise levels (nr=0, nr_level=0). So I have to manually enable noise reduction and set the desired level. Then when I switch back to CW mode with "slice set 0 mode=CW" again the noise level settings are reset (nr=0, nr_level=0) and I again have to manually enable it again. This is very distracting.
It seems that this must have been done by design, why I don't know. So, I'm trying to modify my node red flow to maintain noise level settings with mode changes.
I offer to use the memories in FRstack. More features to be included are available and easier to manage.
I revised my node red flow to maintain the nr, afc and alc settings for each mode as I change modes. All is good now. I then added controls for nr_level, alc_level and afc_level to my Behringer CMD Studio 2A midi DJ controller.
- 369 Community Topics
- 628 The Flea Market
- 85 SmartSDR+
- 422 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 244 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 916 Genius Products
- 333 Tuner Genius XL
- 451 Remote Operation (SmartLink)
- 780 Peripherals & Station Integration
- 996 Third-Party Software
