I still get “interlock is preventing transmission” error
Keith Faulkner
thanks Mike
Can you give us some more information about what you are doing when you see this? Do you have a PGXL/TGXL/AG?
Eric, having similar issue here also.
It appears 3.10.10 reintroduced the interlock issue which had been resolved by 3.9.19.
Setup is a 6700, PGXL, AG, and TGXL.Karl - KB2AS
When replying to Eric's request please add the following
- Remote or local operation
- Versions of software installed on Radio, AG, TG, AG
- Are you able to easily clear the blockage
In my case, when it happens, usually putting the TG in and out of standby clears the lock.
Mike va3mw
Eric, I’m using 8400M
What value do you have in the TX Delay field? I get that message if I forget to set it to something other than the default 0 ms. Mine is currently 30 ms.
- 651 The Flea Market
- 50 Aurora
- 965 Maestro
- 938 Genius Products
