I still get “interlock is preventing transmission” error
3.10.10.3817
  • Eric-KE5DTO
    Can you give us some more information about what you are doing when you see this? Do you have a PGXL/TGXL/AG?
  • Karl KB2AS
    Karl KB2AS Member ✭✭
    Eric, having similar issue here also.
    It appears 3.10.10 reintroduced the interlock issue which had been resolved by 3.9.19.
    Setup is a 6700, PGXL, AG, and TGXL.
    Karl - KB2AS
    When replying to Eric's request please add the following
    • Remote or local operation
    • Versions of software installed on Radio, AG, TG, AG
    • Are you able to easily clear the blockage
    In my case, when it happens, usually putting the TG in and out of standby clears the lock.
    Mike va3mw
  • Eric, I’m using 8400M
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    What value do you have in the TX Delay field? I get that message if I forget to set it to something other than the default 0 ms. Mine is currently 30 ms.
