FlexRadio/Maestro Start up
hochocke
hochocke Member ✭✭
I have difficulty starting my Maestro. Sometimes the Maestro appears to be starting, then the screen goes blank. I turn the Maestro off, and when I start it again, it boots up. Is there a particular amount of time needed before starting the Maestro?
    Answer ✓
    you'll need to open a support ticket as this is not normal. they will help you out.
