Maestro B & 8600 Slice C and D
Hi,
Is there a way access Slices C and D while using the Maestro B with and 8600?
Reggie
HI Reggie… slices are created as you request them. For instance, when you want to listen to two different frequencies on the same band or two different bands. Since you have an 8600, you should be able to open up to 4 slices simultaneously.
Now, whether they are specifically named 'C' and 'D' when you open them, I can't be sure since I don't have a Maestro.
No, the Maestro nor the front panel of the M model radios can access more than 2 panadapters and slice receivers on the display. The hardware isn't capable of handling all four at the same time. You can access all four on the Desktop using SmartSDR for Windows or Mac. If you run the Maestro and SmartSDR on the pc at the same time, both can only use two panadapters at the same time. Or, one on the Maestro and three in SmartSDR on the pc.
- 393 Community Topics
- 668 The Flea Market
- 174 SmartSDR+
- 450 SmartSDR for Mac
- 276 SmartSDR for iOS
- 266 SmartSDR CAT
- 215 DAX
- 389 SmartSDR API
- 70 Aurora
- 980 Maestro
- 952 Genius Products
- 349 Tuner Genius XL
- 129 Antenna Genius
- 310 Shack Infrastructure
- 217 Networking
- 832 Peripherals & Station Integration
- 145 Amateur Radio Interests
