Maestro B & 8600 Slice C and D
Reggie
Reggie Member ✭✭
Hi,
Is there a way access Slices C and D while using the Maestro B with and 8600?
Thanks,
Reggie
  • Reggie
    Reggie Member ✭✭
  • VE7ATJ_Don
    VE7ATJ_Don Member ✭✭✭✭
    HI Reggie… slices are created as you request them. For instance, when you want to listen to two different frequencies on the same band or two different bands. Since you have an 8600, you should be able to open up to 4 slices simultaneously.
    Now, whether they are specifically named 'C' and 'D' when you open them, I can't be sure since I don't have a Maestro.
  • Trucker
    Trucker Member ✭✭✭✭
    No, the Maestro nor the front panel of the M model radios can access more than 2 panadapters and slice receivers on the display. The hardware isn't capable of handling all four at the same time. You can access all four on the Desktop using SmartSDR for Windows or Mac. If you run the Maestro and SmartSDR on the pc at the same time, both can only use two panadapters at the same time. Or, one on the Maestro and three in SmartSDR on the pc.
