GPS no longer working on flex8400
Tried disconnecting the antenna and powering off the radio for 5 min. Did not fix the problem.
Suggestions?
Greg N7RDJ
Without further information as to the antenna placement like ground floor, basement, etc., repositioning the antenna was the first logical thing to do. I had similar experience with my antenna in the drop ceiling in basement near an outside wall. No windows nearby. It only took moving it about 6" or so, then bingo.
There was an error rendering this rich post.
Similar issue here immediately after my upgrade to v3.10.10 I have the GPS antenna outside on a bracket on my tower so it has a decently clear LOS to much of the sky and it had been working prior to my upgrade however the operation has always been characteristically slow when acquiring satellites. There isn't much in the way of diagnostics to help confirm what might be wrong for instance if the antenna is an active design they could confirm connectivity and basic operation by measuring current draw but instead there are no satellites visible etc… Just a continuous yellow light so anyone else seeing issues?
Please open a support ticket.
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
