When using N1MM+ text to speech (TTS) there is no RF output, why?
I have followed the instructions from N1MM+ with the recent TTS feature, for the setup, and when I initiate a TTS, e.g. K1MT, I see on the panadapter the audio signal, but no RF gets transmitted.  Help would be greatly appreciated,
David, K1MT
  • Rich M5RIC
    Rich M5RIC Member ✭✭✭
    In N1MM under Logger+ audio set-up, on the Playback tab, make sure you have the Internal radio codec box checked. If you don't, check it and try again.
    Rich
  • David43
    David43 Member ✭✭
    Hi Rich,
    Checking the Internal radio codec box did not work. If you are able to get TTS to work, would you please call me @ 774-217-0108 to walk me through your setups.
    David, K1MT
  • Rich M5RIC
    Can you get standard .wav messages to play ok?
    This will prove you have all the basics setup.
  • David43
    David43 Member ✭✭
    Never tried this, please call me to walk me through this, 774-217-0108.
  • David43
    David43 Member ✭✭
    Rich,
    Got it working and thanks for the help.
    David, K1MT
