When using N1MM+ text to speech (TTS) there is no RF output, why?
I have followed the instructions from N1MM+ with the recent TTS feature, for the setup, and when I initiate a TTS, e.g. K1MT, I see on the panadapter the audio signal, but no RF gets transmitted. Help would be greatly appreciated,
David, K1MT
You need to get the basics first, make sure the DAX channels are correct, DAX TX is turned on and the right playback channel is selected in N1MM audio,
This gives you the basics, ignore the fact its for SO2R, the audio settings still apply.
Check your settings are the same on page 17 onwards.
In N1MM under Logger+ audio set-up, on the Playback tab, make sure you have the Internal radio codec box checked. If you don't, check it and try again.
Rich
Hi Rich,
Checking the Internal radio codec box did not work. If you are able to get TTS to work, would you please call me @ 774-217-0108 to walk me through your setups.
Thanks,
David, K1MT
Can you get standard .wav messages to play ok?
This will prove you have all the basics setup.
Never tried this, please call me to walk me through this, 774-217-0108.
Rich,
Got it working and thanks for the help.
David, K1MT
- 685 The Flea Market
