Transmit controls disappeared
A couple of questions:
Running 6600M with the new v3.2.31 software. I’m sure this is something embarrassingly simple that I’ve overlooked…but I undocked the transmit controls (EQ, TX, P/CW, RX, Phone), keeping them as a separate window. Initially that worked fine but now I cannot find them! It isn’t as though they are just obscured by any other app being displayed. How do I restore them?
The second question relates to the display on the 6600M itself. From a cold start it now displays Info/Operate/SmartLink Setup. I then go into select the version and Run. Not a real issue but it used to always start up in the latest version without intervention on my part. How do I enable this?
Jeff – G4IUA
Best Answers
#2.. In the lower left corner of the 'select a version' screen, select the gear icon and then Setting> autoconnect
Should work..
AL, K0VM
Al—Thanks. That helped me out.
Click on the “wing” icon, bottom left side of the main SDR dashboard
Alan. WA9WUD
Aaah! Thanks for the answers to both questions. I could have sworn that I'd tried the 'wing' icon on the bottom left side of SDR's dashboard but clearly I didn't. Thanks too for putting me right on the 6600M autoconnecting the desired version; I'm sure both were covered in the documentation but I must admit I couldn't find them. So....valuable advice. Thanks for the help.
Jeff - G4IUA
Thanks, Alan. That worked0
- 681 The Flea Market
- 394 SmartSDR API
- 98 Aurora
- 991 Maestro
- 965 Genius Products
- 353 Tuner Genius XL
- 319 Shack Infrastructure
- 224 Networking
