Transmit controls disappeared
A couple of questions:
Running 6600M with the new v3.2.31 software. I’m sure this is something embarrassingly simple that I’ve overlooked…but I undocked the transmit controls (EQ, TX, P/CW, RX, Phone), keeping them as a separate window. Initially that worked fine but now I cannot find them! It isn’t as though they are just obscured by any other app being displayed. How do I restore them?
The second question relates to the display on the 6600M itself. From a cold start it now displays Info/Operate/SmartLink Setup. I then go into select the version and Run. Not a real issue but it used to always start up in the latest version without intervention on my part. How do I enable this?
Jeff – G4IUA
Best Answers
  • Al K0VM
    Al K0VM Member ✭✭✭
    Answer ✓
    #2.. In the lower left corner of the 'select a version' screen, select the gear icon and then Setting> autoconnect
    Should work..
    AL, K0VM
  • Neil D Friedman N3DF
    Answer ✓
    Al—Thanks. That helped me out.
  • Alan
    Alan Member ✭✭✭✭
    Click on the “wing” icon, bottom left side of the main SDR dashboard
    Alan. WA9WUD
  • G4IUA
    G4IUA Member ✭✭
    Aaah! Thanks for the answers to both questions. I could have sworn that I'd tried the 'wing' icon on the bottom left side of SDR's dashboard but clearly I didn't. Thanks too for putting me right on the 6600M autoconnecting the desired version; I'm sure both were covered in the documentation but I must admit I couldn't find them. So....valuable advice. Thanks for the help.
    Jeff - G4IUA
  • Gary Larson
    Thanks, Alan. That worked
