Flex 8600 3,9.19.37287 dead rx and tx after long tune
I have noticed that after a long tune using HF AT auto tuner it needs some time to find match
when done the radio are quite no tx or rx i have to restart the flex its frustraitng
ok its a beta but!!!!!!!
This is a bit confusing as it is hard to tell what is going on.
What happens if you do not have the tuner in line?
Now it has happend 2 times today talked to a friend on 60m and when i stop TX the reciver is dead tx work
trying to close slice and start again DOES NOT HELP no squelch or NR activated
No Tuner in line Radio needs to reboot there was also a 5 sec glitch no signal then it got back
Panadapetr on maestro waterfall is still but vfo moves its very frustrating.
1 time yeasterday on 40m not a single beep on spectrum its stone dead
Thinking about rollback to prev version.
Update!!!!!
started radio lunch time only rx signals ok. Left my home 14Z and just got home20Z Noticed that Reciver is DEAD nobody at home to touch the radio………………..The transmiter works
To get it working again i have to rebote the **** radio
I mean what THE HECK is going on???????????????????
Help Desk ticket time.
Did that.
Did downgrade to 3.8.23 and left radio on whole night still working lets see if its a sw problem
Tim did not like that but if the radio works ok with this version they have to check.sw
The problem started with 3.9.19
I keep fingers crossed it will work fort some time nw
If you downgraded, make sure you did a radio factory reset as well as that is part of the process. Not doing a factory reset will result in some internal database issues.
- 371 Community Topics
- 93 SmartSDR+
- 424 SmartSDR for Mac
- 270 SmartSDR for iOS
- 35 Aurora
- 246 FLEX-8000 Signature Series
- 937 Maestro
- 54 FlexControl
- 451 Remote Operation (SmartLink)
- 996 Third-Party Software
