Flex 8600 3,9.19.37287 dead rx and tx after long tune
I have noticed that after a long tune using HF AT auto tuner it needs some time to find match
when done the radio are quite no tx or rx i have to restart the flex its frustraitng
ok its a beta but!!!!!!!
    This is a bit confusing as it is hard to tell what is going on.
    What happens if you do not have the tuner in line?
  • Lars Pettersson
    Lars Pettersson Member ✭✭
    edited August 2025
    Now it has happend 2 times today talked to a friend on 60m and when i stop TX the reciver is dead tx work
    trying to close slice and start again DOES NOT HELP no squelch or NR activated
    No Tuner in line Radio needs to reboot there was also a 5 sec glitch no signal then it got back
    Panadapetr on maestro waterfall is still but vfo moves its very frustrating.
    1 time yeasterday on 40m not a single beep on spectrum its stone dead
    Thinking about rollback to prev version.
  • Lars Pettersson
    edited August 2025
    Update!!!!!
    started radio lunch time only rx signals ok. Left my home 14Z and just got home20Z Noticed that Reciver is DEAD nobody at home to touch the radio………………..The transmiter works
    To get it working again i have to rebote the **** radio
    I mean what THE HECK is going on???????????????????
  • Trucker
    Trucker Member ✭✭✭✭
    Help Desk ticket time.
  • Lars Pettersson
    edited September 2025
    Did that.
    Did downgrade to 3.8.23 and left radio on whole night still working lets see if its a sw problem
    Tim did not like that but if the radio works ok with this version they have to check.sw
    The problem started with 3.9.19
    I keep fingers crossed it will work fort some time nw
    If you downgraded, make sure you did a radio factory reset as well as that is part of the process. Not doing a factory reset will result in some internal database issues.
