Sstacks3 Meters Show Nothing
This just srarted in the last day or so. I have the latest version of FRStacks running and connected to a 6400. I have the View Meters option selected but none of the meters, V+, PA Temp , etc display any information. I have restarted the radio and FRStacks.
Any ideas?
Firewall maybe? I would uninstall FRStack, reinstall and let it recreate its TCP and UDP firewall exceptions. If you have a complex configuration that is not to be lost, first export it before the uninstall (File menu).
Hi Erik,
I had done that previously but I did not uninstall. I just tried it again, after uninstalling, with the same result.
I looked around a bit and oddly there was a 64-bit version as well. The uninstall did not remove that so I went ahead and deleted the folder in the Program Files folder.
I can tell you that other functions in FRStack work as expected; it seems as though only the meters are affected,
Update…
I changed the inbound firewall UDP rule to include "Private".
Now the meters populate.
Odd?
Update 2…
OK, in Windows the network was configured as "Public" after changing it back to "Private" I changed the UDP firewall back to just "Private"
The meters work.
Windows update?
- 373 Community Topics
- 101 SmartSDR+
- 424 SmartSDR for Mac
- 940 Maestro
- 54 FlexControl
- 999 Third-Party Software
