Sstacks3 Meters Show Nothing
This just srarted in the last day or so. I have the latest version of FRStacks running and connected to a 6400. I have the View Meters option selected but none of the meters, V+, PA Temp , etc display any information. I have restarted the radio and FRStacks.
Any ideas?
  • Erik Carling EI4KF
    Firewall maybe? I would uninstall FRStack, reinstall and let it recreate its TCP and UDP firewall exceptions. If you have a complex configuration that is not to be lost, first export it before the uninstall (File menu).
  • Geoff AB6BT
    Geoff AB6BT Member ✭✭✭
    Hi Erik,
    I had done that previously but I did not uninstall. I just tried it again, after uninstalling, with the same result.
    I looked around a bit and oddly there was a 64-bit version as well. The uninstall did not remove that so I went ahead and deleted the folder in the Program Files folder.
    I can tell you that other functions in FRStack work as expected; it seems as though only the meters are affected,
  • Geoff AB6BT
    Update…
    I changed the inbound firewall UDP rule to include "Private".
    Now the meters populate.
    Odd?
  • Geoff AB6BT
    Update 2…
    OK, in Windows the network was configured as "Public" after changing it back to "Private" I changed the UDP firewall back to just "Private"
    The meters work.
    Windows update?
