Loupedeck Controller Support?
That would be amazing. It's one of the nicest potential third party controllers out there.0
I have been checking out the Loupedeck CT. Having downloaded the application software, it would appear that it will send midi commands for both push-button and rotary controls. The large knob in the centre would be for tuning, principally. Other knobs on each side could be used for AGC , ANC, Volume, NB, ANF, Power, and loads more. I use SSDR for Mac, and Marcus has already given the chance to set up any MIDI device to command the software without any "fiddle-fiddling", under TOOLS. It really just depends how deep your pockets are as to which device you choose.
The advantage of Loupedeck Live is that there is no silk-screening on the face, so it would look really clean.
Disadvantage as I see it is that you do not seem to be able to write over a png background picture in the same way as you can with the StreamDeck. Also you have got to like touch screens as the Loupe decks are touch, as opposed to the StreamDeck, which is positive switch-contact. Also the Loupedeck software is somewhat clunky. Download the software app (it is free) and have a practice, and you will see what I mean.
I have yet to obtain either of the devices, as I am weighing up my finances currently!
73 de Mike G4GWH
Hallo Mike
I am testing a loupedeck live deck but I can't get it to work with SmartSDR
I am using command line available from FRstack http://localhost:13522/api/Radio/{cmd}?param={val}
but when I press the deck button it just opens a browser page.
Could you please post an example on how you have been settings commands into the deck?
I am using WIN 10 just for your info.
Luca IK2NCJ0 -
Hello Luca.
I have been able to get Loupedeck to command instruct on Windows 10, but only with using touch control or push-buttons. I cannot find a way to get rotary controls to work on Windows 10. I need to point out that I am 99.99% only interested in Apple Mac "eco-sphere" which uses both Midi control signals and also Keyboard short-cuts to control SSDR for Mac. I tested again last night on Windows 10 and have reminded myself that I was was not comfortable with using Loupedeck with FRsstack3, because, as it is using keyboard short-cuts only, I abandoned using the Loupedeck as I found that I could easily accidentally press a keyboard key and get a result where none was intended!!! In other words, if I want to use SSDR for Windows (very unlikely in my case) I would just stick to using keyboard short-cut commands to effect control. I note that Frstack3 has a vast number of commands available, and I also note that many other users seem to use StreamDeck and Windows very successfully. (No rotary controls). There is probably a way round all my issues but honestly, I am quite comfortable with SSDR for Mac and Loupedeck CT as I can easily dictate and remain in command of my 6600M functions!
So, in answer, you will have to wade through the Loupedeck hierarchy yourself as I found it too complicated to be able to write down instructions. The only real way would be to be sat next to you and show you what I have been up to!! Best of luck with it .
Maybe someone else on the forum has had better luck than me, but I am sort of stuck in an "Old Man" rut, being "the devil you know as opposed to the devil you don't", and will sit with my iMac Pro, Midi, and 6600M forever!
73 de Mike. G4GWH
Does the Loupback support websocket commands?
If so, you can run a Node Red server on the MAC and use websocket commands to Node Red, then Node Red can communicate to the radio via native API.
Not sure. Dave. There is a wealth of information on the Loupedeck website, and quite a few tutorials (none of which have anything to do with Amateur Radio). I readily admit that as long as I have it working to my satisfaction in my radio shack, then I am a Happy Bunny!
With both devices (Stream deck and Loupedeck) I am sure that the sky is the limit as to what one can do with them, it is just a matter of getting to grips with the "modes" they work on. Interestingly, I note on another discussion that there is a Streamdeck come out with rotary controls, so it will be interesting to see who can get them to work with e.g. AGC gain, frequency rotary control, or more simply, volume control, or any other variable that Frstack3 or Node Red can offer. I suspect that you are the resident expert as you have some really great discussion posts on the general subject of peripheral controls. Always an interesting read!!
73's Mike.
Mike,
Have you tried the Loupedeck with iOS devices such as an iPad or iPhone with SSDR? I see you have had success using it with Mac. I am an apple user exclusively. I use an iPad for remote operating and am curious if the loupedeck could work with it as well?
A good question! No, I have not tried it on iOS devices as it never occurred to me. Also, I do not work remote station, so do not find the need to hook up iPad etc. I suspect it will work just fine as I have just researched the question and note that in the FlexRadio SmartSDR for iOS manual by Marcus, there is a section called "TOOLS". Section 1.5 covers MIDI Controller, and reading between the lines I am quite sure it will work fine. You have to buy an Apple approved connector e.g. Lightning USB 3.1 Camera Connection kit, and also feed the adaptor with a lightning power source, as the LoupeDeck requires power.
Here is a link to the section on Tools.
I never purchased the app for iOS, so I cannot confirm the availability for midi control list as found on SSDR for Mac.
It is worth a go anyway, so best of luck!!
Cheers.
Mike G4GWH
thanks for the answer.
This deck is perfect to control SSDR because has so many knobs that are perfect for VFO AGC Filters.
Best 73's
Luca IK2NCJ
There was one person on the Node Red group that was using a LoupDeck for his station. I’d have to go back through the posts to see how he was using it.
For anyone still interested in Loupedeck here is some info that may help. I use both Stream Deck with 32 keys and a Loupedeck CT. Stream Deck (SD) is easy to setup with Windows 10 functions but Smart SDR does not appear to have the MIDI learn function that Marcus' Mac version has. The newer SD+ does have three scroll wheels which look like they could be utilized for AGC, Volumes, etc. however it appears you will have to dig into the setup to do so. Loupedeck CT is now a deprecated product but since I inherited one I decided to use it on a MAC Book. I'm happy to say that once I learned to assign a MIDI function to each button and scroll wheel (pots) I was then able to assign whatever is in Marcus' predefined list of choices for buttons and scroll wheels. The appropriate list will display for buttons and wheels. Unfortunately, some items are missing and Marcus doesn't appear to have given us an easy way to add items. I wanted to use the scroll wheels to adjust center and width of the filter as I do with my Yaesu radios. So instead I use them to control volumes of mics, speakers, NB, NR, ANF and WNB. Unfortunately I haven't been able to figure out how to display the current level on either the big scroll wheel display or any of the other displays which really wouldn't be a bother except Marcus' Smart SDR does not update real time. Bottom line is since the Loupedeck is not really designed for our radios there will be short comings that you will have to live with. Pretty much the same with the Stream Deck and the DJ2D deck and the others listed as options.
Hope this helps some one trying to decide,
73 de Tom WA7NPX0 -
Thanks for the heads-up Tom.
Firstly, I had to look up the word "deprecated"!! Yes, I found this on the web:
Loupedeck has discontinued sales of the Loupedeck CT, along with their other products, to focus on the Logitech MX Creative Console.
I have the Loupedeck CT and will be the first to admit that programming it is very clunky and quite hard work, and frustrating. It does actually work ok, but I find myself more often than not reaching for my keyboard, mouse and trackpad (Apple ecosystem here). I have checked out the Logitech Creative Console YouTube videos and website. It rather looks like the esteemed Streamdeck that so many people use but with greatly enhanced flexibility.
Looks like I will be abandoning my Loupedeck and this will appear on my shopping list very soon!!
Mike.
6600M/TGXL.
- 363 Community Topics
- 624 The Flea Market
- 8.1K Software
- 68 SmartSDR+
- 181 SmartSDR for Maestro and M models
- 420 SmartSDR for Mac
- 270 SmartSDR for iOS
- 253 SmartSDR CAT
- 188 DAX
- 379 SmartSDR API
- 30 Aurora
- 232 FLEX-8000 Signature Series
- 930 Maestro
- 908 Genius Products
- 328 Tuner Genius XL
- 120 Antenna Genius
- 291 Shack Infrastructure
- 204 Networking
- 447 Remote Operation (SmartLink)
- 769 Peripherals & Station Integration
- 988 Third-Party Software
