High SWR shown only on 10 meters
Background - 8600 with 3.9.19.37287 S/W
Just upgraded to latest S/W today and cold booted radio afterward along with the PC.
I noticed this problem while on 3.9.18 so I upgraded to 3.9.19 just to see if it went away, it didn't. I show a high SWR all over the 10 meter band, around 1.9 to 2.0:1 over the whole band while I am connected to a dummy load that measures 1.1:1 on my external SWR meter and it also shows the same low SWR on my Elecraft KAT-500 External antenna tuner and the KPA amp. All other bands the Flex SWR meter agrees with the external SWR readings. I swapped out all the jumper cables between radio/amp/coax switch/SWR meter/dummy load and that didn't change the Flex's SWR error.
If I plug a dummy load directly into the back of the Flex the SWR is correct, it's reads very low. If I bypass the Elecraft amp and tuner the SWR still reads high on the FLEX.
I hooked up my trusty old reliable Kenwood TS-2000 to the same coax the 8600 used and it shows a low SWR, about a 1.2:1 while the FLEX shows 1.9 on the same coax at the same frequency. All other bands are OK.
What could cause this?
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsI would first reset the radio and make sure that the ATU isn't confused.
If that doesn't solve it, you'll need to open a support ticket since it is still under Warranty.
Thanks, Mike. Wouldn't the new software load and I did a cold boot after that have reset the radio? It was messed up before and after the new s/w and cold boot it's still messed up.
Dave
Hi Dave, no, that is just a boot. First do an export of your profiles then do a factory reset. After the export, turn off the radio. Then press and hold the power switch until it turns white. Wait for the process to finish with a solid green light.
Radio reset complete. Same problem. I'll file a support ticket.
Thanks guys! 73, Dave
- 322 Shack Infrastructure
- 227 Networking
