High SWR shown only on 10 meters
Background - 8600 with 3.9.19.37287 S/W
Just upgraded to latest S/W today and cold booted radio afterward along with the PC.
I noticed this problem while on 3.9.18 so I upgraded to 3.9.19 just to see if it went away, it didn't. I show a high SWR all over the 10 meter band, around 1.9 to 2.0:1 over the whole band while I am connected to a dummy load that measures 1.1:1 on my external SWR meter and it also shows the same low SWR on my Elecraft KAT-500 External antenna tuner and the KPA amp. All other bands the Flex SWR meter agrees with the external SWR readings. I swapped out all the jumper cables between radio/amp/coax switch/SWR meter/dummy load and that didn't change the Flex's SWR error.
If I plug a dummy load directly into the back of the Flex the SWR is correct, it's reads very low. If I bypass the Elecraft amp and tuner the SWR still reads high on the FLEX.
I hooked up my trusty old reliable Kenwood TS-2000 to the same coax the 8600 used and it shows a low SWR, about a 1.2:1 while the FLEX shows 1.9 on the same coax at the same frequency. All other bands are OK.
What could cause this?
I would first reset the radio and make sure that the ATU isn't confused.
If that doesn't solve it, you'll need to open a support ticket since it is still under Warranty.
Thanks, Mike. Wouldn't the new software load and I did a cold boot after that have reset the radio? It was messed up before and after the new s/w and cold boot it's still messed up.
Dave
Hi Dave, no, that is just a boot. First do an export of your profiles then do a factory reset. After the export, turn off the radio. Then press and hold the power switch until it turns white. Wait for the process to finish with a solid green light.
Radio reset complete. Same problem. I'll file a support ticket.
Thanks guys! 73, Dave
- 379 Community Topics
- 634 The Flea Market
- 139 SmartSDR+
- 260 SmartSDR CAT
- 199 DAX
- 43 Aurora
- 268 FLEX-8000 Signature Series
- 956 Maestro
- 301 Shack Infrastructure
