Tuner Genius SWR Issue
RFord
RFord Member ✭✭✭
I'm currently running SmartSDR v3.9.19...I just upgraded from SmartSDR v3.9.18.
I upgraded the Tuner Genius to the v1.2.17. The tuner has been reset and I have gone thru the procedure to tune my antennas.
I have noticed the Tuner Genius stand alone software is reading lower SWR than the Tuner Genius Software that is running in the Radio Panel. I tried to retune but there was no difference. See photos.
Has/Is anyone else seeing this issue with their setup?
    I created a support ticket for this
  • RFord
    RFord Member ✭✭✭
    Thanks Mike that was going to be my next step…
  • RFord
    RFord Member ✭✭✭
    I received an answer from Flex concerning my question…this was the response:
    The SWR reading on SmartSDR indicates the radio's SWR reading, not that of the TGXL.
    Just wanted to close this issue out with an explanation…
    edited July 2025
    Ah, yes, that is correct.
    This is explains the math.
    https://www.arrl.org/files/file/Technology/tis/info/pdf/q1106037.pdf
