Antenna Genius from PoE?
n8wrl
I've seen some whispers of this so I want to ask outright - does anyone have experience using a PoE "splitter" like this:
(That might not the "the one" - need to research current capabilities)
To get 12V and ethernet connection?
-Brian n8wrl
Mike-VA3MW Administrator, FlexRadio Employee, Community Manager, Super Elmer, Moderator adminOptionsThis might work, but look for a POE with a higher voltage. 12.0V on the TGXL is not enough to make it work reliably. This is why it says 15VDC on the back.
You can safely go to 28VDC.
- 685 The Flea Market
- 102 Aurora
- 994 Maestro
- 970 Genius Products
- 357 Tuner Genius XL
