Transmission problems were encountered using the Flex 6500 on field day. Looking for fixes.
Looking for suggestions for fixes from Hams who have had similar issues.
73!
Sounds like the Yaesu + system was radiating enough rf to overload the scu's (spectral capture units) on the Flex. Especially since both are close together and using the same polarized antennae. I believe there is protection circuitry in the front end of the Flex to protect these units. You were probably seeing this in action.
When we run multiple bands on field day, we make sure the rigs and the antennae are well separated (across the field, if possible) . Bandpass filters on each of the rigs specific to the operating band also help tremendously. Also using different polarizations (dipole vs vertical) helps.
bandpass filters are a must at Field Day. and for operation within the same band, physical separation of antennas is necessary.
We had an old Icom 756 Pro III at Field Day and a 6400m (my 8600 and DuneStar filters were in use so I could not bring them to Field Day. The Pro III was pretty dirty on transmit.
The contest club I belong to has a nice discussion going on various bandpass filters and not all filters are created equal. The members have been doing tests on original ICE, newer design ICE, Chinese cheap filters, and others. Pretty interesting results.Jim, K9YC did a nice write up a while back comparing different filters.
http://audiosystemsgroup.com/BandpassFilterSurvey.pdf
73Dave wo2x2 -
This is an RF overload issue, especially if the radios are on the same band at the same time. It would help if the antennas where not parallel to each other. It might even be an common mode RF issue, so chokes on both feedlines would certainly help a lot. Try Mix 43. A ground wire will not eliminate common mode issues.
If on the same band, bandpass filters won't really help as it is all inband RF.
I am not sure how clean the FT-710 transmitter is, but it might be worth looking into or trying another radio.
- 389 Community Topics
- 53 Aurora
- 971 Maestro
- 945 Genius Products
- 307 Shack Infrastructure
