Screen Saver Maestro & M model
Mike VE3CKO
Mike VE3CKO Member ✭✭✭
This has been brought up before, I haven't seen it as a new idea to vote on so I'll bring it up again. In my case I have a Maestro on nightly at my nightstand as I often wake up through the night. With tinnitus listening or not listening to rag chews has helped and when can't sleep, some rag chew will either put me back to sleep or I learn something, lol. I'm not a sleep walker but I am a sleep lurker, sandbagger.
Problem is the display dimmed down to the minimum is still too bright and though putting a cloth over the screen is simple, it inhibits air flow and in the morning Maestro is quite warm.
I tried using a laptop instead, screen saver works fine but finding my glasses/mouse to change VFO or band requires too much of a bother sometimes. Maestro is quick and easy, so perfect solution for me would be a screen saver, or increase the dim range of the display. I can only imagine to accomplish this and work with all variations of the Maestro the M models would not be an easy task since some used a tablet and nowadays it's a dedicated display.
As a sleep sandbanger, a Maestro screen saver is high on my wish list, much higher than squelch was. One can only hope.
If you too are a fellow sleep sandbager or leave your Maestro, M-model on for long periods of time and would find a screen saver of value, please vote for this feature addition.
8 votes
Active · Last Updated
  • Neil D Friedman N3DF
    Neil D Friedman N3DF Member ✭✭✭✭
    I frequently have my Maestro on my nightstand. Before going to sleep, I face it away from me.
  • KC9KZM
    KC9KZM Member ✭✭
    I would love to be able to put the display to sleep on my 8600M. No point in having the display on when operating remote or when away from the radio-yes I know, just turn it off and the display will "sleep" , "what's the use case ? ", bla, bla, bla..., tape some card board on the display and pretend....
    Still, given the aforementioned suggestions, I believe it would be a useful feature for some.....
  • n0ypd
    n0ypd Member ✭✭
    Another vote for screen saver,8400m. I would like to have the time on the display somewhere.
    My 7610 has Screensaver,and the time. Hope we can add it to my Flex.
